How much 'ansi' needed for viewing in daylight?
lapino
I currently own an Optoma HD70 and am very happy with it, apart from the fact that it's hardly useable in daylight. Especially for playing games which are a bit dark-ish like Splinter Cell, the display is just not dark enough to enjoy the game. When it's darkening up a little, it's a LOT better.
So now I'm thinking about buying a new projector with a lot more ANSI (mine has 1000 if I'm not mistaken). What would I need to be able to game during the day too?
Peter Parker
Other than high lumens, a high gain screen or a grey screen with gain can help combat the effects of ambient light (provided it isn't coming from the same place as the projector).
Your black level is only as good as the light in the room will allow, and high gain screens send the light back in a tight cone either to the seated viewer (angular reflective) or to the projector (retro reflective). They'll also have a similar effect with the ambient light, so depending on your room, seating position relative to the pj and where the ambient is coming from, you may find a suitable gain screen can help.
High gain screens can have issues with 'sparklies' being visible in some conditions, so they aren't necessarily a perfect solution.
Gary
lapino
Screen cannot be replaced, check other thread I started where you follow the build of my home theatre. Screen is fitted inside the ceiling.
AV Nik
Very hard question to answer.
Basically, If the daylight/sunshine hits the projection area, your stuffed. The average UK daylight can be over 50,000 Lumens. However, depending on angles and directions of light, you can effectively project onto certain surfaces. As Gary mentioned, there are several Glass Beaded or High Gain screens which can help in these scenario's.
I've had many demo's and tests on many projectors in daylight situations and when outside, it's impossible but, with a little shade, you can get away with using aprox' 4000 Ansi Lumen pj's but you do require special optics and the shade.
I have a 2800 Ansi Lumen pj here which works well in daylight, without the curtains closed but with the compromise of lower quality video processing. You can find pj's like this from £700 to £1000+.
If you look into the 3000 lumen pj's with high quality video processing, they start around £3000+. Some cheaper options can be found but there are no High Def ones at that price.
One option that many are going for at the moment is buying a cheap 1:1 manual screen, used as a roller/blackout blind. Perfect for instant blackout.
Hope this helps.
