How many wireless joysticks can be used in one room?
Discussion in 'Xbox Forums' started by John Archer, Mar 13, 2006.
  1. John Archer
    John Archer
    Planning to have an Xbox 360 night this week featuring two system-linked Xbox 360s. But this made me wonder if there might be any frequency problems using 8 wireless joysticks in the same room...
    Anyone know Microsoft's official take on this situation?
  2. chedmaster
    chedmaster
    Jan 29, 2005
    2,661
    68
    +28
    I think they automatically choose an un-used channel (theres more than 4) but not 100%
    Otherwise system link would be a bit pointless!
  3. oddfeld
    oddfeld
    Jan 5, 2006
    302
    28
    Edinburgh
    +53
    I seem to remember reading somewhere that you could have up to about 50 pads in the same environment, so you can have LAN parties etc.
    The wireless pad is associated with the last console you used it on. If you take your controller to a mate's house for example, you have to press the connect button on the controller and the other console to get it to register.
  4. meansizzler
    meansizzler
    May 11, 2005
    7,892
    104
    London
    +343
    I heard up to 8 pads..
  5. runam0k
    runam0k
    Dec 16, 2005
    3,458
    London
    +217
    The theoretical limit is definitely up around the 50 mark, so no problems with LAN parties. Not that 50 would be ideal, there may be some interference, but say four 360s each with 4 controllers should work no probs.
  6. runam0k
    runam0k
    Dec 16, 2005
    3,458
    London
    +217
    PS3 is 7. Maybe that's what you're thinking of?
  7. ush flynn
    ush flynn
    Nov 25, 2005
    2,617
    Bromley
    +126
    ok then say if you went to a little link up party, 2 360's 8 controllers... do you have to identify 4 to one xbox and 4 to another, this means you would have to do them 1 by one so that the xboxs dont get confused. You couldnt all be pressing the little button at the same time it would screw itself! probably overheat, 8 red lights on the double rings of doom!
  8. michaelT1888
    michaelT1888
    Jan 26, 2006
    830
    South Lanarkshire, Glasgow
    +13
    There will be no problem if you program four controllers to one 360, and program 4 to the other. The 360 wont recognise a controller if you havnt pressed connect on both. so press connect on the 360 you want to assign the first 4 to, then press connect on the 360 to assign the other four. The connect button is underneath the portable memory port on the console. An on the controller it is at the top
  9. ush flynn
    ush flynn
    Nov 25, 2005
    2,617
    Bromley
    +126
    right but the xbox doesnt care where they are as long as both buttons are pressed, if you have double everything you would have to do 1 at a time
    pain in the ass
  10. Sy1441
    Sy1441
    Apr 10, 2005
    4,487
    Glasgow
    +284
    Yep you would, all you would have to do was
    Press the connect button on xbox 1
    Press the connect buttons on the 4 controllers for that box
    Press the connect button on xbox 2
    Would take about 20 seconds
  11. ush flynn
    ush flynn
    Nov 25, 2005
    2,617
    Bromley
    +126
    ah cool i forgot you just press the xbox button once. i guess thats easy as pie then... mmmmm pie
  12. colinwheeler
    colinwheeler
    Jul 12, 2005
    2,423
    Basel
    +153
    As far as I understand the PS3 is looking to use Bluetooth for thier controllers so that would mean limited by address space and/or frequency interferance (over 100 I am pretty sure) but the stack in each console will only talk to 7 max........as far as I understand on the unconfirmed and constantly changing specs:rotfl: :rotfl: :rotfl: :rotfl:
  13. m40wen
    m40wen
    Dec 1, 2005
    1,248
    48
    Bournemouth
    +32
    And the spec was gotten from young Bob in the basement of your local pub.
  14. colinwheeler
    colinwheeler
    Jul 12, 2005
    2,423
    Basel
    +153
    Oi, I won't have you dissing Bob!!!!!!:mad:
    Nah, think it was from the first press release from Sony actually....which makes it about as valid as young Bob's excellent information!
