How many Tripole speakers in a 7.1 system?
Discussion in 'Home Cinema Speakers' started by Blagmeister, Apr 28, 2003.
  1. Blagmeister
    Blagmeister
    Jun 27, 2002
    Hi All
    I'm deliberating what type of speakers to go for in a 7.1 system.
    Based on a recommendation I'm considering partnering BW601 S3s at the front with M&K K-4s Tripoles at the rears - but what about the side speakers? Should these be monopoles (another pair of 601s) or another set of K-4?
    Thanks in advance for advice.
  2. nathan_silly
    nathan_silly
    I'm going into 7 channel soon..
    sides- dipoles
    rears- monopoles.
    Dolby & THX have conflicting systems, for example you could use bipoles for rears. Or tripoles for sides/rears. And different again with music DVD-Audio discs.
    So basically do what you prefer- borrow each type of speaker (monopole, bipoles and tripole)
