how many pictures on 1 gb memory stick
av addict
hi can someone in the know tell me how many pictures 8 by 6 inchs a 1 gb
sony memoryprostick would take------thanks
bsuttie
Depends on what resolution your images are, what compression they use, bit depth etc.
at 300dpi a 6 x 4 uncompressed 8bits/channel image will be around 6MB, so around 160 images.
With even mild jpeg compression you will get significantly more than that.
HTH
Brian
t1m103
depends on the resolution,the higher the res the lower the amount of photo's,on minium res my pentax takes over 6,000 photos on max down to about 250.
