How many of you shoot in RAW?
Discussion in 'Photography Forums' started by imichael, Mar 8, 2005.
  1. imichael
    imichael
    Nov 5, 2004
    236
    16
    West Sussex
    I'm new to this part of the forums, and it is good to find a photography forum that isn't focussed ( :eek: bugger a pun on the first 20 words) on 'my camera's better than yours' like dpreview.
    I currently have two cameras, a Fuji F810 and a Sigma SD9. I was addicted to the Sigma as, despite the SD9's limitations, it was a huge jump in performance and flexibility compared to my old Fuji 6800Z. Enough waffle, with the Sigma everything is in RAW so white balance, exposure etc can be adjusted to rescue shots or crop and use a specific section (getting rid of blown highlights and bring up dark areas).
    With the the F810 I've left it on wife friendly jpeg mode and find I take more pictures, get better candids, but lose the editing that RAW gives - but get much better use of memory so can rattle off shots with bracketing if need be.
    Does anyone here use RAW on Canon/Fuji etc DSLRs', is RAW ever used on compacts, or is the Ken Rockwell priniciple of blast away in jpeg and rely on proper set up the way forward?
    cheers
    Ian
  2. seany
    seany
    May 1, 2003
    2,997
    61
    Manchester city
    I have a 20D and i have yet to really use RAW that much, mainly because buying it dinted my savings and i've still got the 128mb card from my canon S1. Once i get a couple of decent cards (very soon) i'm get to grips with it
    Only compact i know off hand that uses raw is the canon s60/70
  3. imichael
    imichael
    Nov 5, 2004
    236
    16
    West Sussex
    Ouch - 128Mb on a 20D must be frustrating? Or does it help you think more about when and what to shoot?
  4. imichael
    imichael
    Nov 5, 2004
    236
    16
    West Sussex
    Did you know you can get 512Mb CF cards for under £30 now from danelec, they might not be the fastest cards but should give a bit more time playing when you are out and about.
  5. mr jones
    mr jones
    Oct 23, 2004
    1,041
    41
    (S)cumbria, UK
    +21
    i shoot raw on my 20D because as mentioned it allows me to tweak images etc.
    my only problem at the moment is that im yet to upgrade from photoshop 7 to photoshop8/CS (which will read .cr2 with a plugin) so its a right rigmarole trying to get images sorted
  6. paulc1
    paulc1
    Oct 19, 2004
    397
    +27
    I have used raw with my D70, but the software supplied by nikon for converting the raw images is very poor, and takes months to process on my old and dated pc.
    having said that, I did use tiff images from my fuji finepix s602z, and they were nuch better than the finest quality jpeg.
  7. tomson
    tomson
    Jul 19, 2000
    1,959
    Berk'amsted
    +186
    I shoot in raw most of the time - coupled with photoshop CS it give a bit more 'tweakability' to my images. My raw files do require more work to get them up to standard though - as my D30 gives quite dull, uninspiring raw files straight from the camera - but once run through a few actions and tweaked then they are noticably better than the jpegs.
  8. HotblackDesiato
    HotblackDesiato
    Dec 4, 2002
    1,170
    63
    USA
    +226
    I only shoot RAW...and now do a lot of post processing in RAW that i once did in PS.
  9. mr jones
    mr jones
    Oct 23, 2004
    1,041
    41
    (S)cumbria, UK
    +21
    yeh i found that, the only thing i use photoshop for now is to apply an unsharp mask and to crop if required, ocasionally i use it to **** with an image beyond all beliefs
  10. imichael
    imichael
    Nov 5, 2004
    236
    16
    West Sussex
    with the Sigma you only have RAW, but the supplied SPP software has got to be the best bundled editing software supplied with any camera. I tend to do all my photo tweaking in SPP and then save to Jpeg or TIFF for final cropping and printing from photoshop. I have PS8 and although this reads the Sigma RAW files, I very rarely use it.
    I haven't tried the Fuji in RAW mode other than a quick play with the first one we had which was faulty. It is a great little camera BTW if anyone is looking in the £300 region for a compact, I'd highly recommend it.
  11. seany
    seany
    May 1, 2003
    2,997
    61
    Manchester city
  12. mr jones
    mr jones
    Oct 23, 2004
    1,041
    41
    (S)cumbria, UK
    +21
    looks cool but i dont have $25!
    im still after getting CS so i can combine it all together so i dont have to keep swapping files,
  13. HotblackDesiato
    HotblackDesiato
    Dec 4, 2002
    1,170
    63
    USA
    +226
    Similar here... in fact i've gotten so lazy that for most of my stuff i don't mind using sharpening in RAW! I do use PS to sharpen the odd nice shot i get. Tweaking the shadows i also find is a lot easier in the corrected gamma of PS.
    It's my first winter using digital and i've been processing lots of images out of RAW twice... over and underexposing then recombining in PS to artificially increase dynamic range.
  14. Johndm
    Johndm
    Jan 25, 2003
    1,832
    Bedford UK
    +67
    Just jpeg for me..................does the job...well so far anyway.. :smashin:
    I guess when someone wants to buy one of my aircraft pics for buckets of money for a glossy mag I'm gonna be in bother.. :D :D :D
  15. Bl4ckGryph0n
    Bl4ckGryph0n
    Sep 11, 2003
    43,828
    11
    13
    167
    ::1/128
    +17,078
    I only use RAW on my D70. The main reason is that I am 'anal' about keeping the original...I can't stand the Nikon supplied software, so my workflow is...
    1. Shoot pictures
    2. Import into Photoshop Elements
    3. Create CD from imported pictures - for digital negative storage
    4. Use elements to my hards content in the knowledge that I have got my negatives
    At least with RAW I have my full negative, just like with film...No such luck with JPG...And besides NEF RAW is integrated in Windows XP browser...
