How many interconnects?
Discussion in 'AV Receivers & Amplifiers' started by UselessPratt, May 20, 2003.
  1. UselessPratt
    UselessPratt
    How many Alog interconnect cables do I need to connect a DVD player that supports CD, SACD and DVD-A to an av amp?? ( ignoring the digital cable) Do I need 8 ( 4 pairs)?
  2. jhjerpe
    jhjerpe
    Mar 1, 2003
    701
    2
    28
    North London
    +58
    This is what I did:
    1 for L&R
    1 for Surrounds
    1 for Centre and Sub
    That's three pairs using my maths.....
  3. UselessPratt
    UselessPratt
    So normal stereo outputs can be ignored?
  4. UselessPratt
    UselessPratt
    ( What I am trying to get at is that most DVD players have stereo outputs and 5.1 outputs. Do I need to connect the stereo outputs to use the DVD players onbaord DAC when I am playing a CD? Or do those also appear on the 5.1 outputs...as, I guess, front left right????)
  5. vonhosen
    vonhosen
    Jan 6, 2003
    1,907
    41
    London
    +14
    IXOS 175AV 6 RCA to 6 RCA
    Stereo output will just use the Front L & R of these connections while 5.1 will use all. (A neat cabling solutions as well) I use 2 one that supplies 5.1 in for my SACD player & 1 that supplies 5.1 in for my DVD-A.
    No need to connect up the seperate stereo output.
  6. MarkE19
    MarkE19
    Aug 10, 2002
    17,353
    Rainham Essex
    +2,441
    I don't know if different players are different :confused:
    If I use my DVD to play a CD then I need the sterio connections, otherwise I can only get the digital signal into my receiver.
    But saying that, it might just be that I didn't set the receiver to 'Ext In' :blush: . Will have to try at some time.
    Mark.
  7. vonhosen
    vonhosen
    Jan 6, 2003
    1,907
    41
    London
    +14
    Yep
    Just choose the multi channel input on your amp you have connected from your DVD & it will play back the front L & R channels from that 6 RCA connection for your 2 channel playback (whether 2 channel DVD-A or regular CD)
  8. UselessPratt
    UselessPratt
    Thanks! That saves two cables then. I like that IXOS 6 way. Neat solution!
  9. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    UP have you actually got round to demoing anything yet or are you just getting very confused about it all!
  10. UselessPratt
    UselessPratt
    You know what? Thanks to all you guys there, I can't actually think of anymore questions right now. The confusion is over! Let the buying begin. Well, actually, there are one or two items I have already bought....
  11. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    Good stuff UP, after all this i want to see lots of piccys of your set up!
