how many hours....PLEASE HELP !!!!
Discussion in 'Plasma TVs Forum' started by Zulu_UK, May 7, 2005.
  1. Zulu_UK
    Zulu_UK
    Hi all,
    I have just taken delivery of a 42" Panasonic.
    I have a feeling that I have received a 2nd hand unit or a demo.
    Before I take it up with the store in the morning.....does any one know if there is a function to know how long a screen has been on for..like a counter?
    It is a TH42PE30
    Please help ! :confused:
  2. MAW
    MAW
    Jan 24, 2002
    14,082
    Nr Dorking
    +411
    http://www.avforums.com/forums/showthread.php?t=209854&highlight=viera+service+menu
    There you go. As new, the counter will have no more than 1 hour on. That happens as soon as you turn it on. It's pretty easy to tell, the plastic bag shows wrinkles if it's been creased by removal, the remote batteries should be shrink wrapped, and everything in obviously the right compartment in the accessories box. And the tilt indicator will still be black. If it's red, the lid could have been off and laid on it's side.
  3. Zulu_UK
    Zulu_UK
    thanks mate....
    will give it a go... :hiya:
