how many fans
Discussion in 'Desktop & Laptop Computers Forum' started by jelly, Jun 18, 2004.
  1. jelly
    jelly
    Oct 1, 2003
    1,306
    41
    nottingham
    +9
    as the title says how many fans should a decent pc tower have , just for moving cool air around i have a mercedes tower with two fans on the sidepanel which i can remove as there quite noisy also is there such a thing as a silent fan
  2. GrahamC
    GrahamC
    Jul 22, 2001
    2,259
    Morecambe, U.K.
    +67
    Well none really but only if the temp stays cool enough. If you want to add just one then I'd make it pull air into the box as your PSU extracts air with it's fan. If you go for two then obviously pull/push. Link below for some whisper fans.
    http://www.ultim8pc.co.uk/index.asp?section=products&idd=4
    :smashin:
  3. The Dude
    The Dude
    May 21, 2004
    6,283
    Beverley, East Yorkshire
    +2,601
    I find you get better cooling with the two fans working in parallel in a pull configuration next to the PSU..
    This way, by working in tandem with the PSU you're creating a big negative pressure at the rear of the case, which removes the hot air more effieciently..
    PC cases aren't airtight, and are usually vented anyway, so drawing cool air in at the front isn't really neccesary IMO, also noisier as the fan is closer to you..
    For 80mm fans, the Vantec case fans are the quitest I've tried so far.. bit more expensive at £8-9 but worth it..
