How many discs???
Discussion in 'Blu-ray & DVD Players & Recorders' started by misog, Feb 25, 2005.
  1. misog
    misog
    Feb 24, 2005
    29
    How many discs do I have to try before I can find one make which will work on my recently purchased Toshiba XS32. Every disc I have tried say that they have to be formatted after I have tried to create a dvd.
  2. cuseeme
    cuseeme
    What are you using, DVD-R or DVD-RAM? I fthe latter, what happens after you do format them?
  3. misog
    misog
    Feb 24, 2005
    29
    I am using a variety of DVD-RW discs and they all say that I need to format after I have gone through the "create a dvd" process. I had already initilaised the disc before I started to record to the disc.
  4. Rasczak
    Rasczak
    Apr 3, 2002
    23,108
    Warwick
    +3,736
    What brand of DVD-RW discs are you using? The RDXS32 is very fussy over DVD-RW media.
  5. misog
    misog
    Feb 24, 2005
    29
    The latest I have tried is Maxell 1-2x speed Ver 1.1 . It still say's "The disc is not recognised. Please select disc management and start DVD format from the quick menu" after it has created and then finalized the disc. Obviously the disc will not play after I have followed this instruction.
