how many channels can I record?
Discussion in 'Satellite TV, Sky TV & FreeSat' started by tiger3176, Aug 1, 2004.
  1. tiger3176
    tiger3176
    Hi all. I have just ordered the Toshiba RDXS 32 after all the good feedback from this forum. I was also thinking about getting Sky +. I know that you can record 2 channels at the same time with Sky+, but will I be able to record 3 channels with the Toshiba, or is that not possible. Sorry if this is a daft question, but I'm a beginner in all this. Thank you in advance.
  2. Starburst
    Starburst
    Jul 13, 2000
    17,842
    Ilkeston
    +975
    If you connect it to the SKY+ then you can record two channels on the SKY+ and use the RDXS 32 to copy one of those channels being recorded or a previous SKY+ recording as it is played back in realtime.
    Of course the RDXS 32 can record from any external source and wouldn't be restricted to using just SKY+, you could add an additional SKY digibox or Freeview box.
  3. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    2 sky channels using sky+ and a terrestrial channel using the Tosh.so you could record BBC 1, BBC2 and ITV (2 off sat). But not Sky movies1, 2, 3 at the same times. this makes sense!
