how many cd albums can u put ona nw-hd3 2
Discussion in 'Headphones, Earphones & Portable Music' started by loggerKORN, Apr 29, 2005.
  1. loggerKORN
    loggerKORN
    i dont why on amazon it says i can store 13.000 tracks when i can put 4000 if that,, thats why i got it so i can put all my cd on it and still have room for more ?? and had all i can take from it ???? is the a better why of puting cds on to it
  2. Cardiff Irons
    Cardiff Irons
    Jan 19, 2005
    243
    19
    Auckland
    Could it hold 13,000 tracks if you used the lowest possible quality conversion? If the answer is no, why not send it back to Amazon on the basis of misrepresentation?
  3. loggerKORN
    loggerKORN
    im goin on a long break and i NEED music
  4. HMHB
    HMHB
    Nov 11, 2001
    25,517
    Nottinghamshire
    +3,852
    As has been stated before, it will probably hold 13,000 tracks if you use the lowest rate when ripping your MP3s. All manufacturers tend to quote maximum tracks like this.
  5. HMHB
    HMHB
    Nov 11, 2001
    25,517
    Nottinghamshire
    +3,852
    How long are you going away for ? If you take 3 minutes as the average track length, then 13,000 tracks is equal to 650 hours. So if you listen to music 6 hours a day non stop then you have 108 days worth of music on there. Are you sure you need to take this many tracks with you ?
  6. Cardiff Irons
    Cardiff Irons
    Jan 19, 2005
    243
    19
    Auckland
    Not going inside for a stretch are you fella? ;)
  7. kourosh
    kourosh
    Feb 6, 2005
    13,843
    Portsmouth
    +907
    its 13000 tracks using atrack at the lowest settings 48kps :thumbsup:
  8. kyza
    kyza
    mines got 5500 in 64kps tracks on there and i've only used up 8.5GB, so i might be able to get 13000 without using the lowest possible quality, with 48kps god knows how much i could fit on
  9. kourosh
    kourosh
    Feb 6, 2005
    13,843
    Portsmouth
    +907
    i use 48kps and the quality is quite good :thumbsup:
