How many can fully replace my remotes??
Discussion in 'Home Cinema Control & Remote Controls' started by MicoMan, Aug 31, 2001.
  1. MicoMan
    MicoMan
    What I mean is can they display things like "Index Mark and erase on my remote?
    If I can't get a remote that can do all the commands then its not worth it
    The only one i've seen can connect to a computer and you can lable the keys. Sounds great but at £300!!, Only one of my 5 items cost more than this!
    Are there any cheaper?
  2. Arthur.S
    Arthur.S
    I'd suggest a Philips pronto. Without the charger, you should be able to pick one up for around £140. If you want the docking/recharger thingy too, (I think it completes it myself) then add another £40 on.
  3. KAO
    KAO
    Yep, get the Pronto. I have one (unfortunately I paid a lot more than 140 for it though!) and I now do not use any of my 6 original remotes at all, they simply gather dust on the shelf.
  4. paulw77
    paulw77
    Nov 18, 2000
    613
    28
    Wigan
    +48
    One word of caution - the Pronto cannot emulate remotes that have a 'Transmit' button for programming the timer. My Sony VCR has a remote where you enter the details of the programme that you want to record into the remote and then press 'Transmit'.
    VCRs where you program the timer on screen should be OK.
