How mad is this,Help!
jerry
Iv,e had a Phillips DVDR80 for 6 months and apart from some initial trials it has recorded TV progs with spectacular success and with the best picture which is all I wanted it to do. But now out of the blue when I set up to record either BBC1 or BBC2 it displays NO SIGNAL EXT2. The mad part is I can set up ITV1 C4 or C5 and it works? It doesn,t appear to make any difference which method I choose to make the recording Videoplus, Guide plus, manual.
musukebba
It isn't very mad. The simplest explanation is that you have the channel selection on EXT2 rather than BBC1 or BBC2. Use the '+' button on the remote a couple of times.
JethroUK
If the DVDR80 has guideplus (i believe it does) - the guide settings may have gone astray - it happened to me on BBC1 last week (i put it down to a dodgy overnight update) - enter the setting menu and redirect BBC1 & 2 back internal tuner
jerry
Thanks for the replies and I,ll attempt a solution but before I do; Musukebba at what point do I use the + button? JethroUK this might resolve my prob how do I get to the setting menu? As you may realise I,m not particularly a techno phobe so please be patient.
musukebba
Are you trying to record from the timer, or directly by pressing the <record> button when viewing a TV broadcast? I may have given you an over-simplistic answer before!
JethroUK
if it has got guide+ (i dont have dvdr80)
press "guide" button
put the cursor on any of the menu headings (Grid, Search, Schedule, etc)
scroll to the right until you see channels & settings
just follow the prompts to reset channels
jerry
Thanks for all the help. I have resolved it inspired by your replies, the problem was in the "editor" where BBC1 & 2 had mysteriously allocated themseves to EXT1. Couldn,t have sussed it without you.
JethroUK
glad you fixed it - it'll happen again - i had it happen couple times in 3-4 months - the epg is updated every night - i put it down to a hiccup in the update
