How low to the ground?
Discussion in 'Projectors, Screens & Video Processors' started by Frankeh, Oct 3, 2005.
  1. Frankeh
    Frankeh
    I'm wondering.. When I buy my screen and when I'm putting it on the wall, how high should I put it from the ground? When I watch my projected image I sit in a pretty low comfortable "chair" (something like this: http://www.motherdigital.info/images/page_images2/gamepod1.jpg when I sit in it the back goes further down so I look higher)
    1m from the ground?
    PS: When people buy theirself a screen, are most of them going to project the image on the whole screen or for example 5/6th?
  2. Kramer
    Kramer
    Eye level should be approx 1/3rd up from the bottom of the screen.
    Aim to fill all your screen as the unused portion will decrease perceived contrast & generally make the setup look bad. You want the black border "framing" the projected image.
    :smoke:
  3. Frankeh
    Frankeh
    my eye level is 1m (=3.3feet)
    (my screen is 3.4 feet high and 6 feet width)
    so 3.3feet eye level devided by 3 = 1.1 feet
    so my screen should be 1.1 feet away from the ground, is this correct? 'cause I don't quite understand it :p
  4. psflynn
    psflynn
    Nov 10, 2003
    346
    Swindon
    +5
    Nearly!
    your screen is 3.4feet high - 1/3 from the bottom of this is 1.1feet (ish)
    your eiye height is 3.3 feet which should be around 1/3 up the screen.
    So screen height (bottom of) should be 3.3-1.1 = 2.2 feet from the ground.
