How low is enough?
Discussion in 'Home Cinema Speakers' started by JIT, Apr 19, 2002.
  1. JIT
    JIT
    Mar 2, 2002
    1,195
    38
    Glasgow
    +8
    How low does a sub have to go to give a good bottom end response?
  2. Stewart C
    Stewart C
    In my opinion 20Hz.
    Some go lower but I am happy with the shake rattle and roll at 20Hz
    Regards
  3. JSW
    JSW
    Feb 21, 2002
    4,284
    Staffs
    +333
    How can you test how low yr sub is ?
    I ask because I have the sub in my sig and its rated low is 50hz but im sure its lower.
    On the extra's disc of FF Spirits Within I watched Akiras dream and it opens with some superb thunder, the volume on the amp is easy listening level -47 and my kitchen door rattles in its frame so badly that i have to open it a bit to stop it. Didn't need to open the hall door as it wasn't closed properly and it vibrated open itself.
    The doors are made from mdf so theyre not exactly lite so wat can I do to stop them ressonating so much?
    Bryan
    Oh the amps volume is set at about 40 % and xover 70 hz
  4. Electric Mayhem
    Electric Mayhem
    Mar 16, 2001
    10,629
    United Kingdom
    +2,233
    Test discs such as AVIA or Video Essentials have bass sweeps, speaker test tones etc
    AVIA available here
    www.ovationsw.com
    Video Essentials here
    www.ezydvd.com.au
    Or dvds such as the Phantom Menace that have the THX Optimiser on them.
  5. JIT
    JIT
    Mar 2, 2002
    1,195
    38
    Glasgow
    +8
    What about the Paradigm PDR10 at 27Hz? I've heard good things about it considering it's only £120.
  6. Nic Rhodes
    Nic Rhodes
    Mar 23, 2001
    17,152
    Cumbria
    +1,276
    I would also say 20Hz as a good rule of thumb (14Hz is nice though!) for AV, CD has few signals below 30Hz (the odd organ pipe). What really needs to be said is how loud and how much distortion these subs produce at these low levels. There is little point having a –6dB point for a sub running at say 10 % distortion. Similarly there is little point having a sub having a –6dB point measured at say 80dB when you want to operate it at 100+ dB. The low end point needs to be able to hit the low notes at the volume levels used, with low distortion. Few do this, unfortunately.
    There is a huge difference between manufacturers specifications and real world operations, despite what people might like to convince themselves otherwise with.
    http://www.hometheaterhifi.com/volume_8_4/subwoofers-12-2001.html
    is a useful resource for technical info
  7. General Skanky
    General Skanky
    Jul 28, 2000
    4,251
    71
    Colchester
    +44
    Jase, where did you download the test tones from?
    Thanks.
  8. lmccauley
    lmccauley
    Oct 24, 2000
    3,537
    Newcastle
    +330
    He got them from here. I downloaded them and posted my results here.
    Cheers,
    Liam
  9. General Skanky
    General Skanky
    Jul 28, 2000
    4,251
    71
    Colchester
    +44
    Thank you.
  10. General Skanky
    General Skanky
    Jul 28, 2000
    4,251
    71
    Colchester
    +44
    Liam, the low freq tones are labeled and easy to identify, but what are all the others?
    I've downloaded a couple and there is no way to know it's freq!
    Do you know what freq the tones are at?
  11. lmccauley
    lmccauley
    Oct 24, 2000
    3,537
    Newcastle
    +330
  12. General Skanky
    General Skanky
    Jul 28, 2000
    4,251
    71
    Colchester
    +44
    Yes.
    Obvious now.:blush:
    Thanks mate. I did wonder why the labels went to odd numbers.
    I'll get my coat.:)
  13. lmccauley
    lmccauley
    Oct 24, 2000
    3,537
    Newcastle
    +330
    No probs.
    I don't take the p;ss out of people that make obvious mistakes because it just gets too embarrasing when I do it myself. Like this morning when I nearly drove into a car that was actually turning in front of me rather than going straight ahead :blush:. Boy, did I feel sheepish... :(.
    Cheers,
    Liam
