how low can you go ?
Discussion in 'Subwoofers' started by asdonk, Sep 17, 2005.
  1. asdonk
    asdonk
    Sep 11, 2005
    277
    +20
    what is the better choice for a subwoofer used for music only
    it has to play in a stereo system consisting off a Vincent hybrid pre amp and two 125 watt monblocks, the speakers are clones from the JM lab mezzo Utopia using a 25 cm W conus woofer and going down to 35 hz
    in a 60 litres box
    maybe the new peerless xxls 12 is an option
