How low can a centre speaker be placed?
Discussion in 'Home Cinema Speakers' started by mattross, Nov 11, 2004.
  1. mattross
    mattross
    Oct 23, 2004
    257
    +6
    I'm considering buying an Optimum AV Hi-Fi rack and putting a big Sony Wega on top. If I were to put a centre speaker on the bottom shelf, about 10-15cm off the floor, would it sound odd? The top of the TV would be about 1.7M from the floor, which means it would be a very large gap down to the centre. Could this be improved by angling the centre speaker upwards?
    Thanks.
  2. Nobber22
    Nobber22
    Jun 6, 2002
    2,977
    Berkshire
    +109
    Yes. It's not ideal but a lot better than having the speaker point at your ankles. :)
  3. Mr Cat
    Mr Cat
    Jul 23, 2003
    2,190
    Weardale
    +57
    I agree with Nobber22 - but could you place it on the shelf above (as you mention the bottom one), or even on top of the TV..??
  4. mattross
    mattross
    Oct 23, 2004
    257
    +6
    If I stick it on a higher shelf then other components have to go on the bottom, and I'm not keen on having to crouch to to reach whatever goes down there. It would be ideal if the centre was on the bottom, that would mean all components would be over 40cm off the ground, much easier to reach.
