How loud is Athlon 64 Stock HSF?
Discussion in 'Desktop & Laptop Computers Forum' started by Stellavision, Apr 20, 2005.
  1. Stellavision
    Stellavision
    Apr 7, 2003
    2,398
    Southsea, UK
    +102
    I've just bought my self an athlon 64 3000 and appropriate 939 board today for my new HTPC build.
    Just wondering how loud the stock heat sink and fan is?
    I know these proccessors run cool (certainly cooler than my socket 775 P4) but I want to know whether I need something like a Zalman 7000 before I start building the rest of my HTPC.
  2. Dvml1
    Dvml1
    It depends on what else you have got. It's not loud if you have the usual but if the rest of your kit is quiet then you will notice it.
  3. phresh
    phresh
    May 10, 2004
    215
    Oxfordshire
    +3
    I've not tried my stock cooler although I doubt it is the quietist. You could probably replace the fan easily enough though which would reduce noise. I'd personally recommend getting a better hsf anyway, you'd be suprised at the difference it makes.
  4. Stellavision
    Stellavision
    Apr 7, 2003
    2,398
    Southsea, UK
    +102
    I've just ordered one of the Zalman 7000 coolers. Just hope it fits in my Silverstone LC03 case when it arrives.
  5. Kopite4Ever
    Kopite4Ever
    Mar 15, 2004
    4,373
    71
    Liverpool: European Capital of Football 2005/2006
    +76
    stock HSF is fine. ran it for 3 months and didnt hear it
