how long warrenty
Discussion in 'Projectors, Screens & Video Processors' started by smicker, Aug 15, 2002.
  1. smicker
    smicker
    I see a colur stain ,purple left side green right side very very very slight .......I can live with it . up until 3 Days before my warrinty runs out then I want the latest model replaced with my own crap ATE100 ....... work the system
  2. Guest
    Hi Smicker,
    You've only had the Ae100 for a short while and already you are referring to it as crap (whether in jest or not)
    Its worth remembering that Panasonic have pushed the boat out with this pj, so I think its fair to cut them a little slack.
    If you want a 'perfect' projector then you could always sell up and buy a £3000 model, no?
    El
  3. smicker
    smicker
    It was said tounge in cheak
