How long must be the speaker cables?
Discussion in 'Cables & Switches' started by isko, Oct 17, 2004.
  1. isko
    isko
    Aug 29, 2004
    26
    Is there a rule for the speaker cables length? Cable for surround speakers are really long, because they are following the room corners.
  2. Ian J
    Ian J
    Aug 6, 2001
    25,528
    +4,906
    As long as you are using reasonable quality cable and not freebie bell wire there shouldn't be a problem with long runs around a room.
    Don't overlook flat cable that can run under the carpet though as that can frequently halve cable lengths (if you have a carpet that is).
