How long has it been on?
Discussion in 'Plasma TVs' started by Krance, Jan 6, 2005.
  1. Krance
    Krance
    I have read, on here mainly, that it is possible to access a service menu and see how long your plasma has been on for etc.
    Does anyone know how I can do this on a Panasonic TH-42pw7?
  2. blackmanalishi
    blackmanalishi
    There was another thread on this yesterday, probably worth searching for as my memory's not great...
    I think it was something like "hold down the volume button on the plasma panel, then press the button below the 'input' button on your remote control 3 times and a service menu will appear".
    There will be 2 numbers, one starts with a T which I think is the number of times the plasma has been switched on, the other is the number of hours.
    EDIT: Oh, found the thread - mysteriously titled "Number of Hours on a PW7", last post by timthetam. What I said seems to be right except the labelling bit on the service menu.
    WT = number of times switched on
    PT = number of hours watched
    :thumbsup:
  3. Krance
    Krance
    thanks, I will try tonight
  4. blackmanalishi
    blackmanalishi
    Let us know how you get on - haven't tried it myself yet!
  5. Krance
    Krance
    didn't work for me... I'm not sure it makes a difference but I have the pwD7 version? any ideas..?
  6. blackmanalishi
    blackmanalishi
    Worked for me, so maybe it does make a difference...
  7. Ken
    Ken
    Dec 15, 2000
    362
    Stoke-on-Trent
    Ok, here's the easy way. PW7B
    With the panel on press the status button twice; that's the one with a + sign, below the on/off button.
    Ken
