How long does it take to setup an 885?
Discussion in 'Home Cinema Control & Remote Controls' started by TonyA, Jul 23, 2005.
  1. TonyA
    TonyA
    Oct 16, 2004
    2,765
    London
    +217
    I got my Harmony 885 yesterday - charged it up, and am now somewhere on my 7th hour of trying to setup the f*****g thing!
    I have installed, and removed the software from cd twice, downloaded the software from their site, and installed that, but WHATEVER I do, I can not get the damn thing to load up my codes!
    If I start the application, it comes to the download part each time.
    I've done what the FAQ says to shutdown applications like Norton etc... clear the files in Internet Explorer etc... etc... etc...
    It just seems to hang each time I tryh to do the upload - even though the files have been transferred to my PC!
    I've waited up to an hour for the Internet page to move, but the load bar at the bottom of the screen only seems to go half way no matter how long I leave it!
    Has anybody else had issues? Do I have a duff remote?
    I'm just waiting for Logitech Support to become available today, and will call them.
    :lease:
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    are you on win XP SP2?
  3. TonyA
    TonyA
    Oct 16, 2004
    2,765
    London
    +217
    HI HD - nope XP SP1.
    Phoend Customer Support and managed to get it sorted in minutes - appears I hadn't fully switched of Norton AntiVirus, and it was being blocked.
    Shutdown Norton completely, and it downloaded.
    Full marks to Logitech - toll-free support call, efficiently answered (without going through loads of telephone menu options), and almost immediately connected to the Support Technician.
    I wish more companies would follow this example.
    Now I finally have a working remote, I need to start tweaking it!
    :thumbsup:
  4. dickst3
    dickst3
    Sep 15, 2005
    504
    +4
    How do you turn off Norton completely?
    I am having a nightmare :mad: with it. Spent all evening trying to get the update to download on my 655 :eek:
    :lease:
  5. Richard46
    Richard46
    Oct 15, 2000
    1,796
    63
    London E7 UK
    +120
    I just turn off auto protect on the main menu and that seems to enable harmony downloads. Maybe you need to reboot as well?
  6. dickst3
    dickst3
    Sep 15, 2005
    504
    +4
    I'll have a look but my vesion of Norton doesn't seem to have the same interface window (?) as others. I am not sure where this "main menu" is!
    I think if I reboot Norton automatically starts up :confused:
    I have to say its great having the protection but what a PITA :mad:
    Thanks for the hints. :smashin:
