How long do they last
Discussion in 'Plasma TVs' started by cruncher75, Dec 21, 2003.
  1. cruncher75
    cruncher75
    Nov 1, 2003
    1,228
    southampton
    +87
    just wonderd how long a plasma last for till it dies ive heard 30000 hrs is this for all models ive had mine just over 4 weeks and and done 411 hrs
  2. chrise
    chrise
    Dec 13, 2002
    556
    28
    Hampshire
    +46
    It will all depend on many things. Most manufacturers quote a figure until the plasma reaches half brightness. These are in the range of 30,000 to 40,000 hours. Like many things that will be an average predicted life as the actual life of one screen is impossible to predict.
    Interestingly if you continue to use your plasma at the current rate and the life is 30,000 hours at will last 5.6 years. You have been using it almost 14.6 hours per day.
  3. haujobbz
    haujobbz
    Jun 9, 2003
    1,892
    UK
    +90
    If its panasonic pw6 plasma, only a few months.:devil:
    muahahahahahah:zonked:
  4. MAW
    MAW
    Jan 24, 2002
    14,082
    Nr Dorking
    +412
    Cruncher, you'll get 16:9 eyes! The figures are about right, but this is a half life. If you are not running at full brightness and contrast, your screen can be recalibrated and enjoy another lease of life. Most CRT sets would be clapped out under the treatment you are giving yours in a much shorter time frame.
  5. cruncher75
    cruncher75
    Nov 1, 2003
    1,228
    southampton
    +87
    i use mine as if it was a normal tv for every day use
  6. sdh500
    sdh500
    Cruncher75, how did you find out exactly how many hours it has been on?
  7. MAW
    MAW
    Jan 24, 2002
    14,082
    Nr Dorking
    +412
    Hours meter is in the engineers menu. Don't go playing in there, some of it's pretty scary. Instructions in the sticky above. But cruncher, my normal TV is 2-3 hours a day, inc. kids, how the *** do you find the hours to have it on that long?
  8. cruncher75
    cruncher75
    Nov 1, 2003
    1,228
    southampton
    +87
    well son gets up between 6:30am and 7:30am so i gos on then and then wont go off between 12:00am - 2:00am depends if im on early or lates the next day for work but when hes at play school its on for less as for the menu when the tv is on standby press menu the standby
