How long can a TOSLINK Fibre Optic Cable be?
Discussion in 'Cables & Switches' started by davidrbarrett, Feb 25, 2003.
  1. davidrbarrett
    davidrbarrett
    I need a TOSLINK cable 10 metre long but all I can find online are 5 metre at the longest.
    Can anyone point me in the direction of custom cable makers or is 10 metres just too long?
    thx
    David
  2. nathan_silly
    nathan_silly
    Nope. 10m (for optical) is no problem. I think max length is about 100m.
  3. davidrbarrett
    davidrbarrett
    After a little more searching, found a few places that supply the 10m cable.
    thx
    David
  4. Hawklord
    Hawklord
    Feb 15, 2003
    3,530
    3
    Aldershot, Hampshire
    +294
    I recently bought a 10 mtr toslink-toslink cable for £19.32 including delivery (very resonable I thought) follow link
    http://www.euronetwork.co.uk/acatalog/index.html
    they have different colours,legnths and varying ranges with regard to cost.
    Very happy with it - delivery was next day ect.
    Hope this helps:devil:
  5. mjn
    mjn
    May 24, 2001
    22,067
    Herts, England
    +9,805
    depends if its dark or light fibre.....but a few hundred thousand KM should be fine.....
    so yeah 10 m is no problem! :)
