How long can a phono cable be???
K
Kryton790
Tried a quick search but couldnt find anything specific.
Basically I am running a Yamaha AV amp through which I have sky and a multimedia centre which connects to my PC.
I am looking to utilise the phono "Record out" from the AV amp to run an amp upstairs. The distance from amp to amp will be about 15m. Not intending on running anything too fancy upstairs, probably just some second hand speakers and amp.
Firstly, is this the best way to do this or is this too far to run phonos?
Secondly, will I be able to add to this set up with Y leads (ie for the kitchen) or will this affect the sound??
Thirdly, will this all work using the record out from the AV amp as this appears to be the only output...
Stuart
bsuttie
The signal level and the fact that those connections are unbalanced means that you may well pick up a lot of mains hum / interference along the way.
A tidy way to do it would be to use stereo audio baluns and Cat5 cable, that way the 15m run would be balanced.
Quite expensive however. If you're handy with a soldering iron you could find some suitable transformers and make your own however.
Rec out should be suitable for analogue sources.
regards
Brian
jameslindsey
I soldered up a 10 m cable to send video and audio to a celing mounted projector without issue. But I think the phrase suck it and see needs to be used.
In general the longer the cable the better quality conductor & screening required.
K
Kryton790
bsuttie said:
regards
Brian
Thanks for the reply, I would say i was pretty handy with a soldering iron, have you any more info on this??
I was big in to Car audio when I was younger so have a good idea about the basics.
Stuart
eviljohn2
If you're handy with a soldering iron then 15-20m shouldn't be a problem at all for the cable. Just make sure you do a half-decent job with some half decent components.
The more likely cause of problems IMO is if the power sockets you're using are on different circuits which may introduce hum. More than likely you'll be fine and fixing an earth loop isn't too tricky. :)
K
Kryton790
What components do i need to do this??
eviljohn2
AMc
If you're feeling lazy...
http://cpc.farnell.com/jsp/endecaSearch/partDetail.jsp?SKU=AV04350
I use 2 of these to send RGBs from my SCART switcher to my Projector. I've seen the exact same lead advertised at over twice CPC's price online.
Cable and connectors are very well made and I would expect a video signal to be more prone to interference than audio.
The brand is Tech+link when you actually get them.
K
Kryton790
Thanks for the info guys, now im on the hunt for some cheap hardware
Similar threads
