How is the Toshiba42PW23P delivered?
weyland-yutani
can anyone tell how this will delivered. will it have to be assembled in house or is it delivered whole ready to watch?
oh, and if it does need assembly could i do it or does it need an expert?
thanks
L
Lizzard
It's delivered in one huge box and in one piece.
It weights 62,1 kg and the box got the dimension of 1293(H)x1141(W)x552(D)cm
weyland-yutani
YOWSER!!! i take it you had to cut the box open? i can't imagine lifting it out.
thanks for the reply:)
MrRalphMan
When mine was delivered, the main box just lifted off, but you have to lift the unit from the base as it is quite deeply set into it.
It's not too hard, but two people is a must.
Paul.
:p
⭐ Philips OLED908 TV & Musical Fidelity A1 amp reviews + a look at two home cinema speaker packages
Back
