How is the Toshiba tlp-s30u?
I
Impulse
I am thinking of picking one up for a home theater setup, thanks!
I
Impulse
These are the specs:
_______________________________________________
Includes:
2-year limited warranty
Remote control with laser pointer
Soft carry case
Users Manual
Quick Guide
AC Cable
RGB Computer Cable
Audio Visual Cable
Audio Cable for video
Audio Cable for Computer
CD-Rom
The Toshiba TLP-S30U projector is an ideal solution for presenters who demand quality images and portability at a low price. This feature-packed projector includes a special monitor output connector, allowing connectivity to a monitor in addition to the projection on the screen and enhancing presentations in any setting, including the classroom.
Delivering bright, crisp images, the TLP-S30U projector boast 1,400 ANSI lumens, a 400:1 contrast ratio, SVGA (800 x 600) and XGA (1024 x 768) resolution, respectively, and automatic keystone correction.
The TLP-S30U is compatible with Toshiba's notebooks and Pocket PCs. At five pounds, the projector is easy-to-use with "plug and project" functionality to ensure worry-free, professional presentations with Toshiba reliability, compatibility, and versatility. The sleek design with impressive two-tone magnesium casing adds durability and reliability.
The Toshiba TLP-S30U gives mobile professionals the ability to deliver exceptional presentations with integrated data, video, and audio capabilities and a one-watt speaker for enhancing multimedia effects. Toshiba's new projectors have minimal noise at an extremely quiet 35dBA, ensuring that the projector will not interfere with the presentation.
Specifications:
Brightness (Lumens) : 1400 ANSI
Contrast: Full On/Off: 400:1
Weight: 5.0 lbs.
Native: 800x600 Pixels, Maximum: 1280x1024 Pixels
Size (inches) (HxWxD) : 3.0 x 10.9 x 7.8
Throw Dist (feet) : 4.3 - 36.1
Image Size (inches) : 29.3 - 300.0
Lens: Zoom: Manual, 1.2:1
Digital Zoom
Digital Keystone Correction
Aspect Ratio: 4:3 (SVGA)
Performance: H-Sync Range: 15.0 - 93.0kHz
V-Sync Range: 50 - 85Hz
Speakers: 1.0W Mono
Max Power: 240W
Voltage: 100V - 240V
Audible Noise: 38.0 dB
Special: Economy Mode Lamp
Performance:
Speakers: 1.0W Mono
Max Power: 240W
Compatibility:
HDTV: 1080i,720p, EDTV/480p, SDTV/480i:
Inputs:
Component Video
Video
Computer
Warranty:
Two year manufacturers warranty
Sound good?
Gordon @ Convergent AV
AVForums Sponsor
If it's under £1000 then maybe. Off course you may have noticed that it doesnt list 576i (PAL) or 576P(Pal progressive) as standards it supports. Also all the specs it does mention are pretty irrelevant to the actual performance that may or may not be achievable. when watching movies or normal TV through it.
Best advice is to view one with your chosen sources and those you may use in the future. If you cannot view before purchase then make sure you are happy to take a big hit re-selling it if it turns out badly.
Gordon
