How important is the Hz capacity?
Discussion in 'Televisions' started by emrysdavies, Sep 14, 2005.
  1. emrysdavies
    emrysdavies
    Aug 18, 2005
    451
    +14
    I notice that a number of the quite expensive and well known brands of HD Ready LCD TV's have a frequency of 50 Hz, but I have read and I am also being told that 100 Hz is definitely required if you want to avoid flicker.
    Any views on this subject will be much appreciated.
    Thanks,
    Emrys Davies.
  2. Kalos Geros
    Kalos Geros
    Sep 4, 2005
    2,093
    Croatia
    +136
    I would say that 50 Hz refers only to the fact that it can take 50 Hz input from a PAL device like VCR, Analogue SAT box etc...your display WILL be flicker-free since LCDs are progressive scan devices and any interlaced input will be de-interlaced and run at 75 or 100 Hz AFAIK...
