How important is DV connection on a DVD recorder?
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by GadgetObsessed, Apr 7, 2005.
  1. GadgetObsessed
    GadgetObsessed
    Jul 6, 2001
    2,121
    116
    +908
    I'm considering either a Panny E95 or the new Panny EH50 DVD recorder - both of which are now about £330 - for copying my DV camcorder tapes to DVD.
    The main advantage of the older model (E95) for me is that it has DV-in whereas with the new model I would have to use S-video from my camcorder.
    Does using S-video result in a significant drop in PQ compared to DV-in?
  2. Benfica
    Benfica
    There are pros & cons for each one (DV-in versus S-video).
    1) if you use DV-in
    - your video (DV-AVI), although converted to a more compressed format like MPEG2 (stantard for DVD), is converted in digital domain. There are no Digital to Analogue to Digital conversions. Just a digital to digtal convertion.
    - you will get a chapter mark for each timecode break in the miniDV tape (useful for editing)
    - you don't get time & date stamp.
    2) if you use S-Video
    - Video is converted from AVI to S-Video to MPEG2, wich involves digital to analogue to digital conversion. PQ should be worst. I've tested it for my self and I do find this method to hold a worst PQ. Others might well say that they don't see any diference.
    - you don't get a chapter mark for each timecode break in the miniDV tape
    - you can get time & date stamp if you play your tape with that thing turned on.
    Now ... I have a pioneer recorder (DVR-51000) and a Sony camcorder (DCR-PC330). I've copied around 26 miniDV tapes to my recorder using DV-in and produced a DVD-R for each tape (at highest quality - 1 hr / DVD).
    What can I say ? .... the PQ on the final DVD is amazing !
    HTH
