I know that the use of identical speakers is recommended, how about the use of amps? Is it worth having each channel the same speaker and the same type of amp? How much difference will it make? I presume it would be most benefitial with the front 3...... How about the rears? Would I be able to tell that the amp on the rears is the same as that driving the fronts or should i just stick to lower grade amplification?
Basically, I have my hifi. Should I try and use the same power amps for the surround channels, or is this a bit over the top and i should use lesser amps?
Ad
Ad
