mikimausis
i got help from this forum to solve my problem, so i decided to post this in case it may help someone else.
i sarted by caching this annoying buzz. here is a spectrum analyzer data from TVs back.
you can see the bad boy at 10kHz and at 12kHz. (there were some noise at 5kHz also)
the one that changes pitch from scene to scene is highest one in freqency.
as pointed out in other thread by user pwood, this buzz is reflected from back wall, and gets straight in the my ears when i stand infront of TV. naturaly this high audio frequencies reflects fully from flat wall. so my option is to put sound absorbing material inbetween TVs back and wall to elliminate reflection. kHz frequencies can be nicely absobed by thick sheet of cloth, so here is my temporary tuneup
there is a 10cm space between TVs back and cloth for Tvs cooling. and there is about the same space from cloth to wall just in case something gets thru cloth, then it reflects from wall and is absorbed by cloth for other side.
let me remind, that before this tuning, i was able to hear buzz from 4m (13feet) with my PC on(lot of fans that makes noise) and TV sound on.
now i cant hear any buzzing from 1m distance with all other noises turned off and set TV contrast and brightness at max.
sorry for my english
