How i finalize my DVDRam in DMR-e75V to see in others players?
Discussion in 'Blu-ray & DVD Players & Recorders' started by claudios, Jan 8, 2005.
  1. claudios
    claudios
    Please help
    Anybody know if is possible finalizate my DVD-Ram in DMR_E75V (panasonic) (equal i do in my DVD-R), to see in my computer or other dvd player compatible with DVD-RAM!!
    Claudio
  2. ben223
    ben223
    AFAIK DVD-RAM doesn't need to be finalised
  3. PhilipL
    PhilipL
    Jan 18, 2002
    3,787
    103
    +421
    DVD-RAM is a different type of system to DVD-R/RW/+RW/+R, this gives the advantage of not needing to be finalised, however the downside to this is it can't be played in most DVD Players as it works in a completely different way.
    If it doesn't work in your computer you will need a new DVD reader for it, you can also buy DVD Players that support DVD-RAM although these are the exception and not the norm.
    Try www.videohelp.com, they have a section that allows you to find hardware that will play a particular format, recent Panasonic DVD Players will play DVD-RAM.
    Regards
    Philip
  4. Rasczak
    Rasczak
    Apr 3, 2002
    21,204
    Argyll
    +2,261
    claudios,
    There is a guide to obtaining suitable DVD-RAM compatible hardware here. You may also be interested in the DVD-RAM to DVD-R conversion guide also on that site.
    Both guides can also be found linked to in the FAQ sticky thread at the top of the forum.
  5. claudios
    claudios
    Is realy is tottaly diferent.. I take this dvd-ram .. and put in one dvd-r making that this guide say.. and transform..the system DVD_RTAV in VIDEO_TS. Now i have that i want.. (i have 600 tapes with japanese animation from decade 70 and 80).
    thanks
