How hot?
Discussion in 'Blu-ray & DVD Players & Recorders' started by The Wall, Feb 19, 2001.
  1. The Wall
    The Wall
    Hi guys.
    How hot should a disc be after seeing a movie. Just upgraded my dvd. Got a Pioneer 737 instead of my old panasonic a110. Watched a movie yesterday and noticed afterwards that the disc was fairly hot. Not burning but still... Can't remember that the disc were that hot before. Strange.
  2. Mike Dando
    Mike Dando
    My Sony 725 also heats up discs to a fair old temperature.
  3. Stick
    Stick
    I've had a Panasonic, Pioneer and now a Toshiba and they all heated the discs up quite well. The Panny used to make cd's alot warmer than DVD's.
    ...."They're maggots Michael, you're eating maggots"....
  4. General Skanky
    General Skanky
    Jul 28, 2000
    4,247
    71
    +43
    If the MPEG PCB is located anywhere near the optic then you'll get the heat given off by that board transfered to the disc.
    The IC's on that board do get hot.
    Douch!!......Wot's da madder, da CIA got you pushing too many penzils?
    Work: www.hughes-tv.co.uk
  5. The Wall
    The Wall
    Thanks for all the info guys. Guess I am ok to stage my on dvd-marathon now then [​IMG]Thank's again.
