I am wondering how high should I mount my B&W FPM speakers? These are the rear speakers which are on both sides of the sofa. What height would you recommend?
Hi I have fpm 5 as a centre speaker I simply used the template and wall mounting bracket that it came with the height should be the Same as ear height when sitting down hope that helps if you need any other information give b and w a call their customer service is fantastic
