How high is ok for a plasma?
Discussion in 'Plasma TVs Forum' started by Triggaaar, Sep 17, 2003.
  1. Triggaaar
    Triggaaar
    Apr 13, 2003
    6,021
    +1,135
    Personally I'd like the middle of the screen just above eye level - but then there's the fire-place. And that's where it would look best when off. But is it too high for viewing?
    I realise everyone will have a different opinion. I can't try a picture above the fire, as I haven't moved into the house yet.
    So my question is: what is the highest you'd be happy to have a 42" screen (viewing from 12 feet)? (the top of my fire-place is 135cm = 4'5" above the ground).
    Thanks for all opinions
  2. MAW
    MAW
    Jan 24, 2002
    14,082
    Nr Dorking
    +411
    Much too high for me.
  3. Triggaaar
    Triggaaar
    Apr 13, 2003
    6,021
    +1,135
    I should really add an apology for how repetitive this question must seem. I'm currently reading through search results, but would still like opinions :)
  4. owenw
    owenw
    Jul 19, 2003
    269
    Ireland
    I wouldn't risk placing a plasma over the fire in the first place and you'll end up with a sore neck after a week! Most tellys are only about 30" from the floor to the middle of the screen
  5. Tee Tee
    Tee Tee
    Apr 3, 2002
    125
    Shropshire
    +3
    Mine's above the fireplace - quite high. A bit strange for the first couple of hours, but now I really love it. Very aesthetically pleasing and that's the only place it could realistically go!
  6. mikeq
    mikeq
    The fire doesn't pose any risk to the plasma (as long as there is mantle).
    You don't end up with a sore neck
  7. Triggaaar
    Triggaaar
    Apr 13, 2003
    6,021
    +1,135
    I had a look at your set-up mike - took me a while to find it. Couldn't do me a favour and measure the height of your mantle-piece could you? :)
  8. RossC
    RossC
    Feb 13, 2003
    144
    Ours is above the fireplace, viewed from about 5m away - no probelm with neck ache. Now seems the natural place to watch, very comfortable as you sit back on a sofa.
    Sadi it before, best thing to do is to make a life size paper shape* of your screen and lightly tack it in the proposed position and then sit and look at it for a while on and off. You'll soon find out if it's not right for you.
    * Stick an interesting pic on it ffor added fun....
