Hello friends,
Music gives me life. I consume a lot of it. I have a simple setup that i am moderately satisfied with. This is build not for a home theatre but simply listen to music.
I have a pair of Bowers & Wilkins CM6 S2 ( I know, not ideal, will be working on this next). I love the clean, rich, punchy sound they produce but do lack some depth in the bass. This is why i have chosen to DIY build two subs to match my needs.
Im looking to build two reasonably high-end subs, with a budget of about 1200$. Something that helps me in the low frequencies but even more so gives me a rapid, punchy and tight bass. Ive been reading a lot and it seems to only make me feel dumber than I was before.
I just cant wrap my head around what drivers to get. Size wise i want to keep it small. So im landing on 12". I was thinking a sealed sub, but understood its a lot harder. I have no idea what SPL or sensitivity to go for. What is reasonable? Like i stated, i want it tight and punchy with more depth than i have today.
I understood it is easier to use external amps. Not sure what to look for here.
For the cabinet. My friend is a master cabinet maker and will help with this as long as i provide instructions.
I want to build the most high end pair of subs for my need, Im all up for buying used gear too.
Here is what i know:
Here is where i have been looking for drivers: German site, Polish site, another german site.
I really appreciate all the help and I hope I’m in the right place.
THANK YOU!!
/Nikodem from Sweden.
- I want two subs
- I want the sound to be tight and punchy and as deep as it can go but keeping it tight.
- I want them as small as possible
- Primarily used in a room of about 2000 cubic feet.
- Budget 1200$
THANK YOU!!
