How Heavy...?
Discussion in 'General Chat' started by TaurusDevil, Jun 12, 2015.
  1. TaurusDevil
    TaurusDevil
    Sep 16, 2014
    953
    67
    +470
    Is a concrete slab??
  2. markgodley
    markgodley
    May 25, 2008
    6,864
    +2,469
    depends how big and thick it is. Sizes?
  3. lowmans100
    lowmans100
    Dec 20, 2006
    1,506
    +479
    Depends on the mix and reinforcement.
    2400kg - 2500kg per cubic meter should work for most things.
  4. TaurusDevil
    TaurusDevil
    Sep 16, 2014
    953
    67
    +470
    Possibly 2x2. Ive read somewhere they're about 45kg.
  5. lowmans100
    lowmans100
    Dec 20, 2006
    1,506
    +479
    2 x 2 what, feet, meters inches? And what is the third dimension?
    You need three dimensions to calculate volume.
  6. IronGiant
    IronGiant
    Jun 7, 2003
    67,529
    +48,312
    If you go to Wickes you can sort by weight:
    15 kgs(7)
    31 kgs(7)
    32 kgs(7)
    8 kgs(7)
    24 kgs(5)
    Heaviest ones 31 and 32 kg look like they are 600mm by 600mm by 38mm.
    Lighter ones are smaller either by horizontal dimensions or thickness
  7. lowmans100
    lowmans100
    Dec 20, 2006
    1,506
    +479
    Is he talking about paving slabs?
  8. IronGiant
    IronGiant
    Jun 7, 2003
    67,529
    +48,312
    I hope so :) 2x2 I assume refers to 2 foot by 2 foot, so 45kg isn't far out. But it's more like 30kg.
