How far does your plasma stick out?
Discussion in 'Plasma TVs Forum' started by embees, Nov 12, 2003.
  1. embees
    embees
    ive mounted my screen using a 65 quid ebay bracket, the seller has sold plenty, at first the screws on the screen were no where near long enough so i fitted some stainless steel ones, anyway: Its tough getting your hand behind to tighten the bolts but when done it does seem to sit away from the wall a fair bit, how far should it sit out?
  2. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    A unicol flat mount is 18mm I seem to remember, certainly they are well named.
  3. nealgs
    nealgs
    the AVForums powerbuy for the plasma bracket is about 18mm too, but i've had to mount it to a sheet of 12mm MDF in order to bolt it properly to a stud wall - stupid new houses
    so that's about 30mm extra
    Gary
  4. fuzzybee
    fuzzybee
    Apr 27, 2002
    1,498
    Chesterfield town of the crooked (Spire)
    +72
    Mine sticks out 125mm exactly from the wall to the front of the plasma, i use the official Hitachi bracket for my 42 PD3000 :D
  5. embees
    embees
    mine is 60mm to the back, and 140mm front to wall.. doesnt look bad, just thought it would be closer.. but the bracket was only 65 quid i guess.
