how far do b&wcdm1nt need to be from tv as they are not shielded
Discussion in 'Home Cinema Speakers' started by mick23, May 29, 2002.
  1. mick23
    mick23
    Mar 20, 2002
    801
    uk
    i wish to purchase bwcdm1nt which i have auditioned these are not mag shielded as space is limited ,tv in a corner i want speakers either side of tv but at most can manage about 12" either side max , will this be far enough not to affect my toshiba 28inch tv thank you
  2. Jase
    Jase
    Mar 16, 2001
    10,822
    United Kingdom
    +2,713
    They should be ok a foot either side of the TV. I had some Kefs that werent shielded about 6 inches either side of my TV and had no problems.
    See if the dealer will let you do a home demo first though, then you´ll know for sure before you buy.
  3. mick23
    mick23
    Mar 20, 2002
    801
    uk
    i got dealer to put cdm1nt close to a tv in the store they were ok within 4" of tv but tv was an expensive lowe model have to see if i get trouble when speakers get delivered next week thank you
  4. Tom Braider
    Tom Braider
    No disrespect intended, but in spite of what people have said, there's no guarantee of anything without trying YOUR make of speakers against the television you intend to use.
    I had my Definitive 2002s (big things) about 18 ins from each side of my 28in tv. It stained the edges a little but the tv grew accustomed to it and the staining disappeared gradually (I hardly noticed it come and go). Whenever I moved the speakers and pulled the tv unit out for access, the staining would reappear until everything was repositioned.
    Then I got interested in a Panasonic 36in. So I found one in a showroom, and with the permission of a salesman I took one of those medium sized speakers that you get with those typical midi systems and held it right next to the Panasonic. No staining whatsoever. So I got the tv. What happened when I put my speakers next to it after delivery? That's right - staining. As I could forsee a problem elsewhere and a need to return the tv, I moved the speakers a foot further away to prevent unneccessary damage (albeit temporary) to the screen, and I did in fact return it 3 weeks later.
    If you have very mild discolouration as I had with my first tv, you may find as I did that it disappears after a while. I feel sure tthe same would have happened with the 36in. Certainly, powering it fully off and on to run the de-gaussing function helped a lot.
  5. Patrick vdb
    Patrick vdb
    May 31, 2002
    14
    Maastricht / The Netherlands
    Mick
    The user manual of the CDM-1NT indicates that 0,5 meter is sufficient enough.
    best regards
    Patrick
