How far back would I need to move PJ
Discussion in 'Projectors, Screens & Video Processors' started by NickBull, Apr 4, 2002.
Thread Status:
Not open for further replies.
  1. NickBull
    NickBull
    I currently have a 16:9 80 inch wide picture from my Barco Graphics 808, how far back would I need to move it to increase the screen width to 7 feet or slightly more (i..e another 6 inches onto the width?)
    Also, how much are fixed Stewart filmscreens?
  2. Jeff
    Jeff
    Jul 13, 2000
    5,507
    Basingstoke
    +263
    I recon 7.3 inches (for 86" wide). Email Gordon for a quote on Stewart screens.
    Jeff
  3. NickBull
    NickBull
    Cheers Jeff. I could get that on the existing mounting I reckon. There's a bit of give!
    Nick
  4. Boris Blank
    Boris Blank
    Aug 7, 2000
    1,772
    Outpost 31
    +215
    Nick,
    Do you really need to move the projector? Can't you increase the width using the horizontal width (and vertical height) to get the display to match the 86" screen width.
    I had a quick fiddle (ooh er Mrs!) with these settings on my 801s just now and I can certainly increase the total width of the display by more than the needed 6".
    Maybe your rasters are already maxed out width wise?
    Paul
  5. Roland @ B4
    Roland @ B4
    Apr 11, 2001
    2,238
    Reading.
    +32
    Nick are you saying that your PJ doen't fill the screen or that you are looking to go to a larger screen.?
    Becasue your PJ had partially worn tubes the distance will be critical and may not follow the lens program.
    Paul, beware, your suggestion is one of the quickest ways to get a CRT projector to fail. By expanding the image you could take it too close to the seal which would heat and fail. Not only would it be messy it would be expensive and sudden.
  6. Boris Blank
    Boris Blank
    Aug 7, 2000
    1,772
    Outpost 31
    +215
    Roland,
    Yup, understood, thats exactly why I said that his rasters may be maxed out already in which case the only alternative is to move the projector back.
    Regards,
    Paul
  7. NickBull
    NickBull
    Roland,
    The image fills the screen very well, I was just wondering if the rails the pj is mounted on would allow for a 7 foot screen if I decided to go bigger. I think there's about 9 inches of rear movement.
    Saying all this though, I was playing last night and I think the screen size is more than large enough! But I suppose It would be worth knowing for the future. I think if I even invested in a Stewart screen the temptation would be to go bigger too, just to justify it!
    Thank
    Nick
Thread Status:
