How far away I can I place my rear speakers
Discussion in 'Home Cinema Buying & Building' started by andrewtayloruk, Aug 29, 2005.
  1. andrewtayloruk
    andrewtayloruk
    Sep 29, 2003
    414
    Newcastle-Upon-Tyne
    +10
    I have a 15ft x 13ft living room, 42" Toshiba rear projection in one corner. I'm thinking about putting in a Sony DAV500ZF (or possibly the Denon D500 - depends on price).
    How far away I can put my rear speakers, I'd prefer to have them against the opposite wall so I can hide the cables under the carpet. Will this negate the effect of the surround sound, should they be positioned just behind the listening position?
    Also, I was to spring the extra for the Denon, what speaker stands do people recommend.
    Any opinions?
    Andrew
