How exactly do you use the Enigmah selector?
Discussion in 'Nintendo Forums' started by McGraw, Sep 30, 2004.
  1. McGraw
    McGraw
    Sep 29, 2004
    312
    +11
    I am thinking of using a savegame exploit to mod my XBox for high definition only.
    Once I have done this, how does Enigmah work?
    Do you boot from it, select NTSC and from then on, everything stays in NTSC?
    Do I need to do all of the guoki tutorial or can I get away with just the first bit?
    Also, if I perform this mod, what are the risks and what other benefits will I get?
    Thanks a lot in advance.
  2. H4r7y
    H4r7y
    Jun 17, 2003
    1,713
    39
    Nottingham
    ive not done the mod this way but ive got it on my xbox and all i do is run the program and then select ntcs or pal.
    it will stay on this setting until you run the program again and change it.
    as for the rest of your enquiries, i dont have a clue. never done it
  3. McGraw
    McGraw
    Sep 29, 2004
    312
    +11
    Cheers, I take it your Xbox is chipped then?
  4. jwramsay
    jwramsay
    Sep 7, 2004
    1,629
    West of Scotland
    +72
    I have a modded XBOX (i.e. modchip installed).
    I downloaded the Enighma program and installed the .ISO onto a CD-RW.
    When I boot up with the disc in, it runs. Select A for PAL, B for NTSC.
    Reboot.
    On my Pioneer 434, it says either 525i or 625i for NTSC and PAL respectively.
    Doesn't matter what your game is PAL or NTSC it comes out in the format selected with the Enighma Program.
    I recently installed Slayers EVOX v2.6 and it has the Enighma program as part of the install, so I no longer need this CD-RW.
  5. H4r7y
    H4r7y
    Jun 17, 2003
    1,713
    39
    Nottingham
    yeah, mines got a chip in it.
    pretty much the same as the post above, apart from i dont have to run it from cd, its installed on my hard drive, so i change it from the dashboard.
