N
NickBull
Is there any point getting a Pronto without it? How heavy on batteries is it?
Originally posted by mjn
Its not essential, as at the end of the day, its just a fancy battery recharger!
Heavy on batteries?
Well it doesn't use batteries.....
Originally posted by Timh
I always seam to have to remove and refit the battery before recharging or it will not recharge,I do get 100% after recharging though, has anyone else had this problem?
I also do not leave the battery on charge to long, but I thought the Nimh battery which comes with the docking station could not be overcharge, and can be left charging all the timeOriginally posted by alanrob
I also do not leave my Pronto on the charger as it's too easy to over charge the battery, thus reducing it's life (or like JWS having it go into Global meltdown )
Are you using prontoedit4? since I down loaded this I have to reset my pronto before downloading my latest configeration
Might be true with the battery, but better not take the chance.
I just know that the instruction I have for my portable MP3 players battery says not to over charge it as it reduces the life of the battery. Also say the same for my cordless drill battery
