How does video upsampling work?
Discussion in 'AV Receivers & Amplifiers' started by crawf1982, May 2, 2003.
  1. crawf1982
    crawf1982
    Jun 21, 2002
    183
    East Midlands, UK
    +7
    I am planning to get a Denon 3803 and was just wondering how the video upsampling feature of the unit works.
    If you input a composite/s-video signal can the unit output a pure component signal or is it some sort of pseudo/pretend component signal?
    Thanks for any help/info!
    Dave
  2. gmt steve
    gmt steve
    Aug 19, 2002
    648
    Manchester
    +6
    I don't know how it's done, but I can say that it doesn't change the quality at all. I own a Pioneer VSA-AX10 with the feature, and all it really does is allow you to use the one component connection to the monitor. If the original signal was composite for example, then there's still lots of dot crawl. It's useful, but it definitely doesn't upgrade the signal.
  3. taimur
    taimur
    Jan 9, 2003
    513
    19
    Glasgow
