How does the Panasonic 32PB50 come boxed? is the speakers in the TV box?
Discussion in 'TVs' started by djg1, Mar 11, 2003.
Tags:
  1. djg1
    djg1
    Please help if u know....please.
    I am thinking of buying the Panasonic 32Pb50, however one box is missing to the stand so i would just be buying the TV BOX ONLY.
    And i don't know if the surround/centre speakers are in this box or the stand box which is missing?
    anybody know who has a 32PB50 pana set?
    thanx.
    :hiya: :
  2. Andy ARB
    Andy ARB
    Jul 3, 2002
    33
    Doesn't quite answer your question but I've got the 36PB50.
    The packaging description in the manual says that the centre speaker, the two rear surround speakers and the wiring are in the same box as the stand.
    They refer to it as a "video cabinet/speak pack" and its part number or whatever is "TS-36PBL" so maybe if you did a search on the web for TS-32PBL you might find something that tells you for sure.
    Hope the above helps
