How does RS232 connections work for controlling stuff?
DannyBoy73
I've noticed over the years that various bit of hardware have RS232 controlling ports on the back.
Am I correct in thinking you can hook up your video switch to your processor and have one as like a remote control master? so the master sends a signal to other devices via rs232 telling them all to do something, i.e. switch channel?
garyb9900
Established Member
RS232 as i understand it is for contolling individual bits of kit from a dedicated control system, such as a Crestron, not for simply looping through signals to make it all work from one control/remote (unless that control is part of a control system).
Chris Muriel
The kind of control you are referring to is more appropriate to RS-485; indeed 485 multidrop is used in quite a lot of professional and security video gear for control/switching.
Chris Muriel, Boston (normally Manchester)
Joe Fernand
Outstanding Member
Hello Dan Mason
Serial Ports can be used in many ways - RS232 enabled devices have uni or bi-directional Comms with a control system; where the control system is used to control and monitor other devices.
Some RS232 enabled devices can be used to act as a mini controller for other RS232 enabled devices.
Where you have one or two RS232 enabled devices in your Home Theatre that don't include any form of on-board programmability you don't require an expensive Whole House control system - there are mini programmable hubs from the likes of Aurora Multimedia; see http://www.auroramultimedia.com/?pr...esc=Y&isBen=Y&isSp=Y&isApp=Y&isAcc=Y&isDown=Y
Joe
⭐ Philips OLED908 TV & Musical Fidelity A1 amp reviews + a look at two home cinema speaker packages
Back
