How does map download work?
Discussion in 'ICE, Sat Navs & Dash Cams Forum' started by rollingstone06, May 5, 2007.
  1. rollingstone06
    rollingstone06
    Thinking of buying, somewhere down the road, a TomTom One sat nav. It's SD card will be preloaded with maps of US & Can. I'd like to get maps of western Europe, too.
    After downloading those maps from the TomTom online download store onto my PC's hard drive, I need to copy that file onto a separate SD card -- question is, how is this process done, and what device do I need to achieve this?
    Thanks in advance,
    RS :thumbsup:
  2. ram33
    ram33
    May 28, 2005
    1,150
    48
    +61
    you just need a card reader
    usually under £10
  3. rollingstone06
    rollingstone06
    Hey Ram,
    Thanks for the info!
    Cheers,
    RS :smashin:
  4. ram33
    ram33
    May 28, 2005
    1,150
    48
    +61
    also make sure hidden files are showing before copying over
