How does it know.......?
Discussion in 'Movie Forum' started by markster, Jan 6, 2004.
  1. markster
    markster
    Possibly a stupid question, but if a DVD has both DTS and DD, which sound format does the DVD player choose to use?
  2. graham.myers
    graham.myers
    Mar 11, 2003
    6,230
    Leeds
    +931
    its the disc that chooses not the player. Same as chapter branching etc.
    by default most discs will select DD and its up to the viewer to switch it to DTS
  3. buns
    buns
    Apr 29, 2001
    6,100
    58
    Belfast
    actually, can anyone mention a disc which defaults to dts? Ive never seen one.....
    ad
  4. markster
    markster
    Oh right ........ I'm using a Philips PW9617 with an inbuilt DD decoder - so defaulting to DD is good for me! Only problem is, I'll be wondering now if I am missing out not hearing it in DTS! DOH!
  5. buns
    buns
    Apr 29, 2001
    6,100
    58
    Belfast
    listen to both then and decide! :D
    ad
  6. Geezer
    Geezer
    Aug 5, 2002
    2,833
    68
    +25
    Then switch to dts then. All you have to do is to go into languages and change it.
  7. markster
    markster
    But I got the impression that as my TV has DD only, it wont be able to do DTS? Is this correct. I would have to get a new amp/receiver to hear DTS... (you can tell I'm a newbie at this game) :)
  8. Geezer
    Geezer
    Aug 5, 2002
    2,833
    68
    +25
    Sorry didnt realise, if your amp cant decode DTS then you cant listen to it.
  9. markster
    markster
    oh dear ... so now I'm left wondering what I'm missing - oh well!
  10. Noodle
    Noodle
    Jan 6, 2003
    577
    Peterborough
    Don't worry about it. If you're using your TV as the decoder, you wouldn't notice any difference between the two.
  11. markster
    markster
    lol - thanks.
    Although I suspect that's code for 'your TV decoder is not that good quality and therefore it wont make any difference!'
    hmmm - I think a new amp should be on the shopping list!
  12. Jayb
    Jayb
    Feb 6, 2003
    149
    19
    Nottingham
    Markster are you using the speakers built into the TV?
  13. markster
    markster
    The plan was to use the internal speakers, although I have some rather nice mission 771's which I may hook up through my arcam 7 amp for the left and right channels. Worth doing? I actually think (Delvery of TV is in a couple of days time) that the inbuilt sub-woover may be the weakest link.
  14. Jayb
    Jayb
    Feb 6, 2003
    149
    19
    Nottingham
    I am no expert and pretty new to this myself, but I think you need at least a 5.1 set up to take advantage of DTS, 2 rear, left and right fronts, centre for speech and a sub.
    Also you would need that set up for DD 5.1
    The difference between a 5.1 set up and just using the tv's speakers I'm sure would be vast, it is with my set up....:)
  15. Noodle
    Noodle
    Jan 6, 2003
    577
    Peterborough
    TV speakers....Yuk.
    If you can use the Arcam & missions from the L/R preouts and set the centre channel off (still using rear TV speakers) you should get pretty decent results.
  16. figrin_dan
    figrin_dan
    Jan 9, 2003
    2,042
    +155
    To answer your original question - Don't rely on the disc to choose which track. Some default to DD 2.0, and you wouldn't want that!
  17. markster
    markster
    Doesn't the DD rely on the fact that you have a centre speak/channel for the dialogue? If I turn it off on the TV would I not miss quite a bit?
  18. Noodle
    Noodle
    Jan 6, 2003
    577
    Peterborough
    I've never come across a disc that defaulted to 2.0 if there was a 5.1 soundtrack.
    Why would they want to do that?
  19. wilber
    wilber
    Sep 29, 2002
    1,970
    +30
    Godzilla R2 came bundled with my first dvd player - that defaulted to 2.0 rather than 5.1
  20. Noodle
    Noodle
    Jan 6, 2003
    577
    Peterborough
  21. Geezer
    Geezer
    Aug 5, 2002
    2,833
    68
    +25
    So did dog soldiers when i played it the other day.
  22. figrin_dan
    figrin_dan
    Jan 9, 2003
    2,042
    +155
    Alien and Fight Club also. Apparently if you only have DPL, 2.0 sounds better. I tried it and thought the downmix was the better track.
  23. FoxyMulder
    FoxyMulder
    A disc which defaults to DTS, i have 2 Cutthroat Island DTS Japanese version and Tomb Raider also Japanese version.
  24. zantarous
    zantarous
    Dec 11, 2002
    2,205
    113
    +686
    All the Superbit discs I have defaul to DTS
  25. Jeff
    Jeff
    Jul 13, 2000
    5,507
    Basingstoke
    +263
    My DVD player defaults to DTS if the track is available. :)
  26. figrin_dan
    figrin_dan
    Jan 9, 2003
    2,042
    +155
    None of the Superbit discs I have default to DTS.
    Maybe it's a player thing.
  27. richard plumb
    richard plumb
    Jan 27, 2002
    14,477
    Windsor
    +1,046
    I thought it was against DVD forum specs to default to DTS. DD compatibility is part of the minimum standard, and all players can play this / downsample to stereo for TVs.
    But not all DVD players support DTS, and not all TVs/processors will decode it. So you have to select DTS yourself, and the DVD normally warns you before you confirm.
    Maybe this is different with an all in one system supporting DTS, I'm not sure?
  28. HMHB
    HMHB
    Nov 11, 2001
    26,714
    Nottinghamshire
    +5,469
    My Panasonic TV has onboard DD and DTS and I can definately tell the difference, especially now I'm using the Pioneer 565.
  29. James45
    James45
    Sep 21, 2002
    2,844
    59
    Taking Care of Business
    Japanese R2 Superbits default to DTS, certainly the Jurrasic Park trilogy does.
