how does dve disc work
Discussion in 'Plasma TVs Forum' started by gunner84, Sep 1, 2005.
  1. gunner84
    gunner84
    Aug 16, 2005
    3,571
    +726
    hi
    just got the dve disc to set up my pv500
    i just wanted to know how it works as it seems to be all talking or does it calibrate the tv as its playing ,hope someone can help ,or explain to me how it works.
    thanks
  2. NonPayingMember
    NonPayingMember
    Previously Liam @ Prog AV
    Oct 18, 2002
    8,523
    Kent
    +830
    You need to watch the talking bits to learn how to use the test patterns which are indexed on the disc. Once you've seen how adjusting what effects the way your plasma shows each pattern then you skip ahead to the patterns and carry out the adjustments using the colour, contrast, brightness etc controls on your plasma screen.
    Unfortunately automatic calibration is as good as impossible!!!
    If you do a search some members have gone into detailed discussions on maximising the best from certain patterns.
  3. gunner84
    gunner84
    Aug 16, 2005
    3,571
    +726
    ok thanks
    so i just pause the dvd player on the bits what have all the colours e.g and then ajust the tv in its menu.
    when should i do the basic calibration, do i need to run the plasma in for the recommened time first (pv500 --- 150-200 hrs).
  4. NonPayingMember
    NonPayingMember
    Oct 18, 2002
    8,523
    Kent
    +830
    You can navigate to patterns that stay still on-screen while you adjust - no need for pausing (which probably isn't a good idea). Do a basic calibration right now if you want to be watching the best image the plasma can give you. After a run-in period, as the phosphors settle you will notice changes in the way the plasma displays grey scales, so a quick re-adjust with the disc again is advised.
