How do you turn on DTS in Mummy Ultimate Edition?
Discussion in 'Movie Forum' started by Sun, Aug 24, 2005.
  1. Sun
    Sun
    Oct 8, 2003
    773
    28
    Stowmarket, Suffolk
    +34
    I was having a fiddle last night, as you do, and I stuck The Mummy & The Mummy Returns Ultimate Edition on and could only play in DD5.1 and not DTS, both films have DTS and my amp and DVD player are capable as well so I don't know why it wasn't working. I tried Gangs of New York and it played in DTS when I selected it in the menu and Blade 2 played in DTS ES 6.1 when I selected that as well.
    So where is the setting for turning DTS on in the Mummy? It's region 2 I believe.
    Infact on a similar note where is the DD5.1 setting in 24: Season 1? I had similar problems with that before as well.
    Sun
  2. davidjohnson
    davidjohnson
    Aug 19, 2005
    2,455
    63
    +144
    I am not certain, but I believe the region 2, series 1 of 24 only has DPL.
    I have the region 2 Mummy 4 disc Ultimate set myself and I am sure I was able to play the Mummy in DTS. I will check and let you know.
  3. Sun
    Sun
    Oct 8, 2003
    773
    28
    Stowmarket, Suffolk
    +34
    thanks davidjohnson, that would be great, the packaging definitely says DTS on it, so unless Amazon have sold me packaging from one region and discs from another then it must be right surely?!
  4. davidjohnson
    davidjohnson
    Aug 19, 2005
    2,455
    63
    +144
    Hello
    I have just checked both films and they both play DTS.
    I pressed menu, then toggled down to languages, selected DTS, then confirmed my equipment is able to play DTS (I hate it when a DVD asks you that). It then played the DTS intro (the piano thing) then the films started with DTS sound.
  5. Sun
    Sun
    Oct 8, 2003
    773
    28
    Stowmarket, Suffolk
    +34
    They have the DTS setting in languages? :suicide:
    Right thanks for that david I'll check it when I'm home tonight.
    Sun
  6. Mics49
    Mics49
    Jul 30, 2004
    945
    28
    +58
    Aeh... Where else do you usually find them (if not in "set-up" => "soundtrack" or => "languages")? :rolleyes: ;)
  7. Sun
    Sun
    Oct 8, 2003
    773
    28
    Stowmarket, Suffolk
    +34
    Well mr clever cloggs, I've never seen one in Languages before so never checked in there, it seems a bit stupid to me, "do you speak DTS?". Setup or features I can understand but otherwise it's just silly.
    I found why 24 Season 1 is only playing in Neo Cinema as well, it's only a DD2.0 DVD, tsk. Although Neo6 is doing a fine job at 5.1.
